ron-c said:Extreme,
You need to go to the MVP861 set up menu to play back multi-channel and adjust your settings. Reading the manual cover to cover is a must with a universal player. They are very complex!
Thanks,
Ron-C
EXTREME5 said:Hi Ron,
Thanks for your response.
Indeed, they are very complex.
As you suggested, I read the manual from cover to cover, and worked with my mac dealer to remedy the problem. None of this seemed to fix the problem, so a fresh unit is on the way.
Apparantly other owners are also having problems with the unit reading certian discs. They too, are having to make mutiple attempts to load the discs.
Comments please.
Thanks in advance, Miles
masterlu said:Strange, all of mine are perfect.
Josh said:I have this issue, but have yet to have it spring up with an SACD. On regular CDs though, it is hit or miss. I have had the same problems on 3 seperate 861s.
That's funny.. I thought the 201 wasron-c said:Over the past year the 861 was again the largest selling McIntosh model.
Thanks Ron,ron-c said:On the 871? First one selects video output type and second selects resolution that is set for the selected video. Component would be 480i or 480p.
HDMI or RGB would be 480i/576i, 480p/576p, 720p, 1080i, or 1080p....
We have the NTSC and PAL thing going on as this is a multi mode player set up for US and overseas sales..
Thanks,
Ron-c
Thanks,
Ron-c
ron-c said:Jerry,
Machines sold into the US domestic market are stricly Code 1. I would rather not say more than that but you should discuss this with your import agent in Sing. as far as options.
thanks,
Ron-C
Maybe because mac is victim of its quality, mac amps last forever!ron-c said:Jim, the other post was from August, the 861 sales were for the whole year through the end of December. When you add in the MDA/MCD1000, MR85 and MS300 we are the source component company....
Thanks,
Ron
