I am to understand the main benefit is going wireless ? You can hook an external to anything .
You can hook an external what to anything?
sorry, dac.You can hook an external what to anything?
I really have no need for anything wireless either. TV and volume remote is all I have.I have a BlueSound Node and control it exclusively from a PC, I also have a smart phone, which has the Android App for the Bluesound installed, but I never use it for this, as I regard this as only a backup. I also don't bring Bluetooth into the equation as I have no use for it.
Both the desktop PC and the Bluesound are hard wired to the network, I could easily connect both to the network via WiFi, but I am happy with it as it is.I really have no need for anything wireless either. TV and volume remote is all I have.
No, as said above, PC and Bluesound are connected to my service provider Router via cables. You need to have an Internet connection for the Bluesound - as its primary function is streaming from the Internet.Your pc plugs into the bluesound node?
No I don't think so, I think that would depend on the speed of your WiFi Internet connection, which as you may know can vary continuously. Hard wired of course uses no WiFi bandwidth and has a much more stable connection speed. I have several other WiFi devices around the house, so I just wanted to spread the load a bit, however hard wired is more secure. Wifi coverage in my house is a bit spotty for some reason, that was another reason for going hard wired.Do you feel there is better SQ hard wired?
yes. I was just establishing in my mind that he had the whole chain hardwired.The steamer is connected to your local network, either wired or wirelessly.
The control device is also connected to your local network, either wired or wirelessly. You can have multiple control devices.
For example, I have my streamer's control app loaded on my hard-wired desktop PC, my wife's laptop, my Android smartphone, her Apple smartphone, and an Android tablet. When we want to change the music, turn it on or off, search for music, turn it down, etc, we use whichever device is handy.
The control device communicates with the streamer over the local network. Both can connect to the local network (your router) physically or wirelessly.
I assume you have a local network (a router) in your home, and you have a computer.
Get a streamer. Connect it to your network, wired or wirelessly, and connect its output to your stereo system (or alternatively to an external DAC, with its output connected to your stereo system).
Download the streamer's control app to your computer.
Subscribe to a streaming service that's supported by your streamer.
Done.
Your Dac is fine. I would Definitely keep it for now. If you want to upgrade later by all means do so.
Your Dac will work with windows 7 however that clock is ticking. Spotify works with Win 7 but for how much longer?
I would strongly recommend you aim for one of the Hi-res companies such as Amazon ,Quboz , or Tidal.
Your internet has to be a minimum of 10mbs for Amazon. Amazon music will not work with win 7.
You can test internet speed on whatever device you are using to connect to AK. Just google internet speed test.
What are you using to view AK?
Laptop< Dac<to Amplifier is my current setup.
You may want to consider using your budget for a newer laptop that runs Windows 10 or 11 .Doesn't need to be powerful. Basically plug and play with the very capable Dac you already have.
Keep it as simple as possible.
You could use the Chromebook with the Dac now -as long as you have the correct cables- just to see if you like it.I have a modern cheap chrome book lap top. I stream upstairs with that using the smsl. I was just trying to use one of my old laptops to stream on my main hi fi to just see if that would work first. I will most likely get an old phone and the wiim streamer and then get a better dac for my main system downstairs.
