Yes, the one pair of speaker connections are a limiting factor, but you are bi-amping. I considered doing the same thing with a pair of F112's and my two MC275's before the 501's got my attention. The MC275 is simply a fantastic-sounding amp, and I will be keeping mine for a long time! If I were in your shoes, and looking for more tube power, I would be eying those MC2301's myself. Do the 2301's sound anything like a 275? your SF's must be very effecient, to be able to enjoy driving them with one 275!:yes:
There is quite a difference between "passive bi-amping" and "active bi-amping". In my case (active bi-amping) the 275 does not "see" or reproduce a full range signal and since most of the power is used up by the bass and the F112s take that load, the 275 has a much easier time driving the speakers. (Bryston 10B splits the signal before it gets to the 275 and F112s)
In a passive bi-amping (bi-wiring) setup both amps still see much of the full range and reproduce most of it except that it is absorbed by the crossover in the speaker and converted to waste/heat.
The 275 "drove" the SF Memento's all by itself but it sounds much, much better in the active bi-amp mode with the F112s doing the "heavy work". There is no congestion (straining while reproducing "macrodynamic peaks") and no tube glare (over-emphasis of the upper mids and the "presence region" during complex musical passages, aka "brightness and leanness").
The key to bi-amping is having gain and input sensitivity of the amps match unless you like uneven frequency response.
