Rega Owner's Thread
Interesting. The proper link would be this: http://www.rega.co.uk/html/RP3.htm
I wonder what some of AKers would make of this:
"Mass absorbs energy - lost energy equals lost music"! Rega has pioneered the use of lightweight rigid plinths. Clever use of lightweight particulate core with a highly rigid phenolic resin skin became the foundations of the high level of performance achieved by the now iconic Planar turntable range. The RP3 takes this design philosophy to the next level. A super lightweight plinth combined with a phenolic resin double brace mounted specifically where the increased rigidity is required (between the tonearm mounting and the main hub bearing) forms a structurally sound "stressed beam" assembly. This rigid plinth design prevents energy absorption and unwanted resonances which will add unnatural distortions to the music. Equally, heavier mass can transfer more unwanted energy such as motor or bearing noise directly into the rotating record. The use of braces instead of the complete skin allows double thickness phenolic resin in these key areas while providing further weight reduction to the plinth which directly addresses the issue of mass absorption and unwanted energy transmission.
Actually I think this deserves its own thread. I might just do that.
I don't know maybe my web browser is playing a trick on me but check your post again you're directed to nowhere really.
Mine is directed to the Rega page but not specifically the RP3 (just used it from the latest Mozilla Firefox). Your browser is playing tricks.
OK so I picked up the P3 wool mat and it's definitely much higher quality than the felt mat that comes with the RP1. The improvement is audible as well with better detail retrieval and tighter bass.
So last night I was fussin with the anti skate and decided to turn it down to zero and guess what? Yeah, much better. Anyone have a P1 or RP1 and have this experience?
Well a month later and the results of the mat and anti skate changes are mixed. I'm going back to the stock mat and recommended anti skate for a few weeks and will report what I hear and what the mixed results were.
Give me some hours to post photos....look at my signature...:thmbsp:
Sorry for the delay... I have some photos here. Next upgrade: groovetracer deluxe subplatter and acrylic platter, Gallo Reference 3.5 speakers and M2Tech for the notebook...:banana:
I forgot... behind the Aleph Ono there is a MF V-DAC... fantastic performer for the price...:)
Very nice system! I would suggest getting the Groovetracer Reference Subplatter vs. the Deluxe. It's worth the extra $30 to get the delrin pads which decouple the platter from the subplatter. It's really a high quality product.
Thanks Erocka.... yeah... you were right about the Reference subplatter.... what is the delrin pads?:scratch2:
I wonder whether the delrin pads are really better. When I ordered a GrooveTracer subplatter I decided against the Reference model because I wasn't sure they'd be a good thing. I'm still not sure. I do wish I had the opportunity to compare, though.
Well, if you ever make your way out to Brooklyn, you can come have a listen :)
Delrin is a thermoplastic, with very low resonance. On the reference subplatter there are three pieces of delrin that the glass platter rests upon. It seems that a lot of turntable companies are implementing delrin more and more these days. I assume that's because of it's low resonance. The Clearaudio Concept's entire platter is made of delrin.
So $US30 extra for three delrin dots? Looks interesting.
Has anyone here used their acrylic platter and what did they think when they chucked the mat- Sound?
I do love Brooklyn. I feel a road trip coming on.:scratch2:
My hesitance with the pads is based on the rigidity and hardness of everything else on my P5. It's one reason I like the Goldring Eroica on it. The Eroica is built very rigidly. Turntable materials don't get much harder than those used on Rega's best turntables. GT's subplatters are something to marvel at, though. Frank is quite the craftsman.
I have a P25 with a Shure V15-V. I'm going to do the white belt (no matching shoes) and Groovetracer subplatter upgrade soon.
I have a P25 and have had the white belt for a month now, and the Groovetracer is on it's way. The belt has made a slight sonic improvement, and the speed is closer to dead on than it was with the older belt. I look forward to hearing the changes with the subplatter.
Rega Planar 3 Upgrades:
Groovetracer Reference Sub-platter / Groovetracer Acrylic Platter.
Rega White Belt / Michell Tecno Counterweight.
These four upgrades have significantly improved my Planar 3.
Next upgrade will be to swap out the old motor for the new 24 volt motor.
Future upgrade / TT PSU.
atuque
Does anybody know if the Funk Firm Acromat 3mm will work on the RP1? Also do you own the JA Michell Rega clamp? How do you like it?
Naive question from a stock P3 owner. What are the sonic benefits of the Groovetracer subplatter?
Yeah, questions from another Planar 3 owner- to atuque- did the reference sub-platter make a pretty big difference in sound?
What was the old motor on the planar 3- was it a 12V motor? I assume getting the new motor upgrade (24V) would hopefully mean I could finally use the 45 setting on the SDS without changing the belt pulley? Apparantley the old motor was not enough of a load for the SDS to switch to 45 mode and I had to change the belt pulley instead. A total pain.
Do you use a mat with the acrylic platter upgrade?
southp / Dukiedook
I will try to answer your questions as best I can.
With the original plastic Rega sub-platter there was a "wah-wah'" effect that was most noticeable on music that contained solo piano or solo acoustic guitar. Rega owners attributed this effect to the stock platter being somewhat "out of round".
The new sub-platter is precision machined to eliminate the "out of round" of the stock Rega platter. Because the new sub-platter is round, the "wah-wah" sound has been eliminated. Solo piano and solo acoustic guitar sound much more solid.
I do not use a mat with the acrylic platter. There may be advantages to using a mat, such as changing records on the fly, but this is not an issue for me.
atuque
