Carguy1394
One of the measurement conveniences I use, is to use the output (it is the feedback point too) point of the amp as the black dmm reference when I am measuring the push pull driver circuitry. Then with a significant DC offset from ground (+0.3v) the ground referenced readings may be, for example, +2.1v and - 1.5v while actually +1.8v and -1.8v is being delivered to the pre-driver transistors.
Soldering iron temperatures delivered to a transistor are well outside of their operating conditions. Possibly even damaging.
Please don't set yourself up with a red herring.
One thing to pay close, careful attention to is the base to emitter voltage on each driver. When it is not similar to the Vbe voltage of about 0.6 volts there is a problem with that transistor.
Q13 is a bit "too far back" to be affecting the magnitude of the driver voltage. It's function is to deliver the audio to the NSA circuitry, which splits the audio into two streams of different voltages, controlling the positive and negative halves of the push pull drivers.
. Assuming that Q15 is delivering the correct current, the components that set the driver voltages above and below the output voltage are Q17 & Q19 for the NPN positive side drivers (Q29, and GWX-593 Q1) and Q21 & Q23 for the PNP negative side drivers (Q31, and GWX-593 Q3).
An overall rule of thumb for the NSA circuit output driver voltages is that they should be roughly symmetrical at rest. And be 3 x Vbe's in magnitude. (Q29, GWX-593 Q1 & multiple output transistors in parallel)
a side note: tomorrow I have a significant Physican's appointment, so I will be absent at some point for an unknown interval.
I will follow these instructions. Thank you Mark for your time and expert advice. They are priceless to anyone involved in repairing NSA amplifiers. Take care of your health - it's the most important thing. We all believe that you will be back soon to the forum and help us with your experience and professionalism.As a baseline, it would be a good idea to measure and record the dc offset voltages and idle currents of your good, reference board.
Once new trimpots for vr1- vr4 are installed (*), a second check to see if there are idle currents flowing at full CCW ( zero ohms) would be a good idea.
* ( on the belief that you found problems with even the reference board's trimpots.... iiac )
