Carguy1394
"Just in case, I gotta ask; When doing ohmmeter readings, the power is turned off?"
Yes.After every measurement power OFF, Discharging the big capacitors with 200 Ohm resistor and after that , shorting them. And before every turn ON first DBT until the light go to dimming and than plug into 120 V and measure on 120V.
So what we should do with this plate if has no issues . I just finishing the other measurements with variation with a VR1/VR2 on 4 stages from 0 to 100 Ohms and just stuck into the MS Exel to post the results , but will take a time. If we need it. The base voltage is regulating from 1.6V to 1.985 v for each channel.
To connect the next plate with a problems? There 3 more left.
