Awesome. Thank you for the service manual!Hi, attached..
No scanner so I tried to take pics with my phone..
Jeff Tolbert
I have an M4a. It just has the fans under the unit. They are so quiet I have to look under it to see if they are running. The amp does run real hot. At least mine does. I wonder if that is why they added the rear fans? You might be able to get quieter fans? All those computer type fans are pretty quiet. It might be the picture but the left fan almost looks to have a wire in the way of the blades.
Hi,
I own a few of the M4 exvlusive amps.
No noise at all from the bottom fans.
Yes there is a vented metal bonnet under the wood case. Top has vents .
Acabler
HiThank you for the info! Does your M4 have fans at the rear? I find it strange that their are fans also at the rear. Most likely modified?
Hi
Only on the bottom on all of the 4 units that I own..
They do get pretty warm if anything is placed on top.
Might be why they added to on the back plate.
When working properly it is a very nice amp. The rear fans and holes are not original. Not sure what you are paying but the rough cut holes in the rear might lower its value considerably?
