beatcomber
AK Member
Spendors love tube amps with grunt. 50+ watts with KT88s or 120s and you'll be back in the glass game.
I would love to get there someday....
I also wish to know how to open the grille of SP1/2, they are so tight!Anybody know how to get the grilled of a pair of SP1 speakers. I would like to check and see that drivers are all fastened tightly.
Jeff
I wish to make sense out of the naming convention of the Spendor SP line of speakers: SP X/Y RZ
Like, what do all these (and the whole lot of the rest) mean:
SP1/2
SP1/2R2
SP2/3
I would like to try the new Yamahas someday.After A/B comparing my A-S1100 and Rogue CMII, I've concluded that the Yamaha emulates the tube amp sound by at least 9/10ths - even the 3D effect that many SS amps cannot manage at all. So there you have it - if you want tube sound and SS convenience with Spendors, get a Yamaha MOSFET integrated.
For reference the sound stage envelope of the CM Dos is greatly expanded using the better NOS small signal tubes, some much more than others.
Jeff
I agree.
Has anyone replaced/upgraded crossover capacitors?
Another question, my speakers are missing the foam port plug that was added to BC-1 and BC-2 to tighten bass. Anyone know how big that foam port plug is? What depth?
I'm listening to BC-2's through a Fisher 800c
Thanks
Paul
They came without front foam and i won´t mount some, so i changed the mounting of back and frontplate so frontplate is flat now ( without reflections from the edges ? )
All x-over Caps are MKT - Foils and in their range, so nothing to do here - just cosmetic by removing the black colour from the real veneer, oiled with teakoil, waxed..
I gotta try that.
I am using an accupowertool for screws - this machine must been used so the accus stay alivebut every 3-5 years seems excessive.
Schönen !
Hi Paul,
i am now owner of a pair BC1-Germany- Speakers, Report follows here later.
I think its a late version of the BC1 with Fuse on backside and Biwiring terminals.
The Crossover Components have been changed by Spendor as follows:
i will describe changes from top ( Coles Supertweeter )
1. Capacitors changed from input (left) side 1uF to 0,68 next 1uF to 0,47
2. Resistor 33 Ohms don`t exist.
Celestion HF1300 Tweeter:
1. Tweeter is connected in Reverse Polarity !!! ( The black cable is soldered to the red dot on the Celestion )
2. Capacitors 0,47 and 0,33uF changed to only one C with 1,5uF
Midbass :
1. One resistor 220 Ohm/5Watt is added parallel to the 3,3uF MKT
All inductors and coils values haven´t changed.
All changes look for me like made in factory, because the soldering points look virgin.
The ports of my BC´s are 3" diameter and have a lenght of 16 cm, at the output they have a phase. No foam was insert.
So i tried several versions of foam insert - with the result of decreased bass every time.
Only thing i did, was to put in foamliners of 4 Millimeters thinkness but complete lenght into the ports. This is a damping for some midtone frequencys reflectet from the backside of the midbass.
In my Spendor Preludes this will work good, without them i hear unnatural deepnes of the " stage "
Good Luck
Juergen
I wonder if the crossover and port revisions were market specific?
It would be cool to compare the sound.
