Tube Radio
If an amplifier introduces noise into a powered sub through the plate amp's speaker level inputs, there's something wrong with the main amp.
This thinking is why I'm done with this, have fun.If an amplifier introduces noise into a powered sub through the plate amp's speaker level inputs, there's something wrong with the main amp.
not missing anything, the sub driver is seeing a completely different signal than the mains in your scenario, it's seeing both amps where the mains are not, and the sub amp is seeing a completely different signal than the main amp, nowhere is this a good thing.
if you think it is you're fooling yourself
The sub amps are designed to be as neutral as possible so they will blend with whatever mains you happen to own.
Stating preference is useful but arguing preference is fruitless.
I'm not going to get into a back and forth discussion with you because I know how that turns out.
What you state above has no relevance because the internal sub amplifier is a given -- there is no way to eliminate it. The sub amps are designed to be as neutral as possible so they will blend with whatever mains you happen to use it with. How perfect that internal sub amp is is also irrelevant -- the only thing you have under control is how to feed you feed it . You want to feed it with the best signal possible for a given set of circumstances. For a 2-channel system, from the perspective of wanting the sub to act like an extension of the mains, feeding it with the exact same signals that the mains see is unquestionably going to be more uniform than feeding it with a preamp that is decoupled from what the mains see. From a "minimizing noise/distortion" perspective, feeding it with the preamp is unquestionably slightly lower noise due to bypassing the 2-channel amp in the signal chain, though none of that noise or distortion will be audible at all in any decent system, and that signal is decoupled from what the mains are using to produce almost all of the audible sound (except for the tiny portion the sub fills in at the lowest frequencies).
The fact that the sub has its own amp is irrelevant because it can't be removed from the equation, but you still have the obligation of feeding the best signal possible. Again, I will not at all suggest my preference for speaker-level is the answer for all 2-channel systems (that has been in my personal experience though), it's just important to state the plusses and minuses of both approaches instead of talking about one and ignoring (and/or denying) the other.
never heard of a passive sub?
It's useless, again, done here.
Most regular subwoofer plate amps have phase shift closer to 20Hz due to a high pass filter and may have phase shift due to an LFE low pass filter.
However higher end subs may not have that phase shift. I don't know as I've never really owned a real high end sub.
The best way to see what if any phase shift a subwoofer plate amp has is with a dual channel oscilloscope and audio frequency generator.
The audio generator goes to the subwoofer input and scope channel 1.
The speaker output (if one side of the speaker wiring is grounded) goes to the second scope channel.
Both are adjusted so the traces are on top of each other. Set the plate amp to a decent output and adjust the V/div on the second channel to where the waveform at 50Hz very nearly fills the screen. Then adjust the input V/div and variable control until the input signal waveform is the exact same amplitude as the output.
Set the crossover to its highest frequency then vary the input frequency from 20Hz until your normal crossover frequency setting.
If one waveform leads or lags the other closer to 20Hz then you have phase shift and must eliminate it.
If you can bypass the crossover or the plate amp has a separate LFE input use that instead.
If the waveform leads or lags the other at your desired crossover frequency, the LFE filter will need to be removed.
The high pass filter is usually a couple caps in an OP-AMP stage that need to be much larger in value. The LFE filter is usually a couple caps in an OP-AMP stage that need to be removed completely.
Do that and the sub will integrate much better.
It doesn't, it's just added noise.
That's the nice thing about the amp in the Von Schweikert sub shown above- there IS no LFE filter. It's designed to be a 2-channel-system sub.
And, with the continuously adjustable phase control- matching phase with the mains at the crossover point, is a cinch.
I don't think many people realize, how downright useful a continuously adjustable phase control is, in a situation like this. If you really want a good blend, it's probably the most elegant way of doing it...
Regards,
Gordon.
And that high pass filter will introduce an undesirable phase shift.
I have a plate amp that had a 20Hz high pass filter and the phase shift from that filter started at about 40Hz.
Then again who needs a high pass filter on a sub unless it is to protect the sub from frequencies that would damage it if it is a design where the driver can unload from the cabinet below a certain frequency and destruct itself due to over excursion.
Isn't the idea for a sub to reproduce frequencies the mains cannot reproduce?
So exactly how are high level inputs on a sub worse?
For each their own- but I've never been satisfied with using a tube amp straight from the preamp for the highs, and a SS amp straight from the preamp, for the lows, in any bi-amp situation I've worked with. You could ALWAYS hear the difference between the damping and the transient response between the two- they never seamlessly integrated, to my satisfaction.
It's less noticeable for a sub (low frequency crossover)- but if you get up into the midrange for the transition- it's especially distracting and detrimental.
Rel started this mess to set themselves apart by eschewing line level inputs and starting the rumor it was somehow superior, some drank the coolaid, others didn't.
