All electrolitycs replaced along with 4 film caps in the preamp section. Death caps on order. All controls cleaned and lubed. Small transistor sockets deoxit treated. Drivers and outputs were marked, removed, cleaned and re-greased. I attempted to test those Germaniums but quickly realized that they can't be reliably tested with DMM. Knowing that unit produced output before removal from the console, I powered it up on DBT. So far - success! No weird noises, no hum and great sound with floor standing 8ohm test speakers. FM hum is gone! Happy!
Most of caps I used were radials and I soldered them with handshake to original capacitor leads. This helped eliminating flimsy construction. Several caps that were located near chassis wall got attached using Marine Adhesive. It's a really strong, sticky, non-acidic silicone. Works great for securing capacitors.
Few minor issues to track down:
Tuning meter does not move in FM. Works in AM just fine. Some testing to do.
Headphone jack is MONO and second channel wire is dangling around the area. Maybe it was a Stereo socket originally but something other then headphones was inserted and broke one of the prongs? Kid stuck a pencil in?
Dial bulbs... 51mm long. I can get away with making extension caps to slide over caps on 41mm LED bulbs, but if I go LED, I want to try Green. I got them for my 400 but I can't remember where I got those. If anyone knows - please let me know.
Below: L-R 400 bulb, Executive bulb, 41mm Warm White LED with add-on caps, ...
