Personally I would keep the stock stuffing as is.
I disagree about removing it.
El-Seven is contradicting himself a bit-yes made by audio engineers-if so there must be a reason for the damping materiel.
2 reasons,(1) perhaps to fine tune the interior volume, but (2) more like to reduce midbass/lower midrange reflection from bouncing around in the interior and cause problems. You just fluff it up and distribute it evenly. It won't affect how the woofer operates-it's pretty light, unless you really pack it in next to the cone.
It can effect the passive some-but the movement of the passive eventually pushes it back-you just want some free space between the woofer and passive.
You could line the interior with foam-but IMHO just leave the stuffing-same amounts etc-as it works just fine with stock components.
I wanted to see the bracing, because I have seen 2 different types, yours and front to back. The latter may have been DIY.
Audio engineers don't always get it right. A number of reasons why this is the case.
I think most of us that have been around a manufacturing business can easily point to a few.
One here I can easily point to is the deletion of a foam ring of similar apparatus to prevent the lower frequencies from wrapping around the Great Heil housing and canceling- true when the Heil is crossed over low, like the AMT1a's.
This cancellation effect has been fairly well documented for a number of years, and adding foam wings to the sides does make a audible and measurable difference. Somewhere I have 2 articles saved on this, including measurements.
Nothing wrong with tweeking, that's the spirit of DIY and Audio Karma.
IMHO it's more of a embracing and a real appreciation of the product, then just letting things be, as is.
Hell, were would we be if we were all satisfied with the status quo.......:scratch2:
All of the OP's and members questionson this thread are valid ones IMHO-so far anyway.
How do you know if you don't ask ?
None of us with born with innate knowledge.
These threads provide a rich source of information, opinions and experiences.
Sure you have to pick and choose, filter if you may, but that's the way it's always been.
