I don't think anyone is saying that at all. They clearly are high quality, only that better yet exist out there, though for the most part at notably higher cost.Are you saying either the Jelco or the SME is not a high-quality arm?
Can we also just say Practical High End. P.S. The current SME 12R tonearm is for all intents a 3012 decendant.
What is the difference in-between say a Jelco SA-750L and an SME 3012 that is much more expensive? Can one hear the difference?
Diminishing- for some reason I misspelled a word I know how to spell.
But you are aware that these arms are several decades old?
Yes, I think from almost everyone I can think of who has run the 750 I cannot think of one who did not think it very fine and a relative bargain. I'm about to put to use a Sumiko MMT that I have; elder, shorter relative of the Jelco 750. Not quite as good by most reckoning, but still a considerable arm. There are some terrific older arms and some new ones. Perhaps the very best to be had are newer, but the basic technique and materials to make a first class arm have been around a long time indeed.No doubt. But isn't there always something out there "better"?
Even high end arms have arms that are better, albeit more expensive.
What arm sits at the pinnacle of cost vs. performance? I don't know but the Jelco is certainly a very good bang for the buck at ~$750.
a bud of mine has a thread at diy audio titled "http://www.diyaudio.com/forums/analogue-source/173861-my-latest-iteration-nanooks-219-tonearm.html"
you can build an arm which is as good or better than the 3012 SME for dirt. Best regards Moray James
With all due credit to your friend's ingenuity, when it came to a decision between "company who has been making highly regarded tonearms since 1959" versus "bloke in a shed with an arrow shaft, a saw and a bulldog clip", I know where I'd put my money...
Age of a tone arm has nothing to do on whether it should be considered high end or not. The Dynavector DV 501 was introduced in 1977, and certainly is a high end arm even today. The Eminent Technology II linear tracking air bearing arm was introduced in 1982, and an updated version in the 2.5 is still in production. The SME type IV and V were realeased in the late 80's, they are a high end arm.
Arms from Technics in the EP 500 and related arms are still considered some of the finer arms out there. Arms from Fidelity Research are sought after and valued for their performance. As are arms from Lustre and Grace. As are arms from Ortofon, SAEC, Syrinx, EMT, and a bunch of others.
I don't know what kind of definition you use to determine what a high end tone arm is, but age should really not be a factor.
Regards
Mister Pig
If I were spending $750 for an arm, I would at least take a look at Audiomods. The kit arm can be built for about $550 with very high-quality wire; an assembled arm is about $750.
http://www.audiomods.co.uk
I built the kit, and it was a quantum jump over my previous RB300. Much, much better in every respect.
I'm curious if this is actually true. While there have been improvements in some types of manufacturing techniques and some materials, labor costs have gotten much higher, and the potential market is small enough that it must be cost prohibitive to set up a production line that can take advantage of some of these advances for such a small number of products.When it comes to tonearms, cartridges, speakers, cables, platters, damping and maybe other areas, developments of material, chemicals, microscopic assembling have taken a HUGE step forward from the years of the outdated tonearms in debate here.
I haven't kept all that close attention on the very high end, partly because I'll never have that kind of money, but also because what I mostly saw was more and more attention to conspicuous consumption regardless of whether it had anything to do with performance (half inch thick face plates, gold plated tonearms etc.).
I also have to say I don't see evidence of all that much innovation in arm design in terms of materials or assembly. The Well Tempered Arm was truly innovative, and that arm (Shick?) with the magnets might also be, but for the most part, most of the arm improvements I am aware of simply reflect the fact that if you spend more when designing and making an arm, you can do more than if you spend less (assuming the same amount of smarts in both cases). Which is not the same a HUGE step forward.
But I'm happy to be shown that I'm wrong. But so far all I see is the claim being made.
I could serve a pallette of goodies here but to convince you I will just point out a very few examples:
#1
Materials.
Carbon Fiber
This material were not in any production line in the 70s/80s
Really?![]()
