Idler wheel "magic"...
Gusten, your measurements are too coarse me thinks. The transients discussed here are micro-seconds, maybe nano-seconds in length. There couldn't be enough accumulated in delay in a 1/3 of a minute to measure by seconds.
What nano-seconds do You mean?
gusten
all this motor talk makes me ftretting my Trio`s motor as it was originally designed to run on 100 volts in japan not 120 as I have been running it on for years. but it shure does a good job. If anyone knows how in the long run this will effect the motor, let me know. I believe its a 4 pole sycro motor anyway and that it is a ac type motor
It is nevertheless an interesting measure of drag, or the lack thereof. It's easy enough to see the difference between drag and no drag.
What is being claimed is simply that the start of a heavily modulated groove puts so much additional drag o the platter that it causes a momentary instance of wow or flutter -- a change in pitch for a brief duration.
That is such an astonishing claim that it really needs to be documented. If it exists at all it should be incredibly easy to document by any competent lab, and failure to notice it or engineer around it would involve an unheralded level of engineering incompetence.
It astonishes me that since platter weight and rotational inertia are such strong marketing themes, that such a phenomenon could exist for decades without some company or another exploiting it for marketing advantage.
We're talking about possibly audible differences in the rise time of a single note on a piano as heard on an idler or rim drive vs. belt or direct drive. The differences in rise time have to be very, very short intervals of time. Do they not?
could the record company's by now come up with a way to cut the album so as not any turntable would need antiskate? seems like it would be possible to cut the grooves at an angle to compensate
Isn´t this what´s called 'begging the question'? We do not know, if it is a difference, that stylus drag has anything to do with it, I think.
gusten
Stylus drag is a given. No debate and measurable for certain. I'm just saying you need a much finer measurement to tell the difference between coast down on a blank groove and coast down on a highly modulated grove with a 20 second sample. If coast down took 20 minutes, you might not see a second total between the two tests for a whole album side.
Really don`t know if stepping the voltage down to what it should be 100 volts is gonna change a wonderfully sounding table bad sounding. Given as it should the motor is heating up quite a bit. we talking egg fryin. But since this motor has been running this way for years now what would be the outcome of making its input voltage what its supposed to be now. Oh god I would sheet meself if it ruined the table:scratch2:
Albeit off topic the short answer is for a given non-resitive load, ie. a motor, lower voltage means higher current which means higher temperatures (as you discovered). It won't fail catastrophically, but it will fail sooner. If you care about it for the long haul feed it the correct voltage.
Thanks I thought so to and went ahead and ordered a 300 watt one for 30 bucks . I doubt the motor uses that much :scratch2: but who knows
the motor is about the size of 2 fists put side by side. This table has so little to none info almost for specs. But the motor doesn`t spin the platter but a pulley . so ifigure it can`t be needed to be real hefty power wise
washing machine motor HUmmm I got an old washing machine motor in the garage lol its gotta a bigger motor can I adapter it lol
no puns intended just wanta thank you for your help. I have forgot most of the basic electronics I was taught in service 45 years ago.
Yup. Also the max size code allows without a dedicated circuit, yet the code does require a dedicated circuit for the washing machine. I think he'll be just fine with 300w.
