Idler wheel "magic"...
If power factor is 1, then 746 watts = 1 hp. Power factor isn't 1 in the real world and efficency isn't 100%. A fair rule of thumb for real word is 1kW = 1HP so I shorted you about 33 watts :)
Dominicl if you are hearing rumble then the idler free wheeler IS coloring the sound. The only thing is its an overall smearing , Kinda like the music is just almost out of phase somehow. If this is the case please check the shaft your idler is spinning on is light oil ONLY. Believe me on this I went thru it on my Trio:banana:
Daniel, the sound coming from my speakers is actually quite the opposite with the freewheeling idler. It is clearer. BTW, the rumble is only at unlistenable volume levels with full bass, and only on the ariston and not the empire. Just did that to see if it is there. :D
A couple of thoughts.
What's the highest torque belt drive table? Something like an Empire maybe?
Was just thinking about the Oracle approach to this. Substantial platter with the big rubber weight on the outside, plus a substantial, for it's size, flywheel on the motor also.
Finally, don't know if this had been mentioned, but it makes you wonder if stylus drag was one of the reasons for the move to lighter arms and light tracking weight that came on around the same time as the the big move to belt drive.
Just ruminating....
crankin up the old volume control and bass to check DominicL? I`m heading for the door I don`t hit with woofer blowin up lol Been there done that and that old flame linear <phase> 400 shattered new space boundarys . It had a surge while I did it and took out out some woofers and more horrible damage careful that knob
If its any consolation, I did it on the lost wax section of the record. No music!
Just ruminating....
Eric, I am guessing the power and torque of the pabst hysterisis motor of the empire and reko have to be up there. However, I don't know how powerful the high end belt drive tt motors are. This and a few other posts here have me thinking again! Will post up shortly!
Some belt drives have small lower torque motors, some large. Some are locked in place in relation to the platter (VPI Classic, similar to an Empire with a fairly torquey motor), some have them in a separate pod detached from the plinth and its bearing/platter. Some use rubber-band like belts. Some have something more like string or a thread. There are far more differences than just lumping all belt drives, all DD, etc, together as the same approach.
I'd go with ROK, or, a Bogen-Presto, or some of the other late 50's/early 60's decks with large motors, for belt drives with loads of torque.
One of the higher torque BDs may have been the tape drive ROK 33H, large-ish out-rotor synchronous hysteresis motor. I got one very cheap and let it go to another AKer as I already had plenty of needy orphans and no interest at the time to do anything with it.
It's a Papst similar to the one used in empire and as a replacement motor option on TD-124s.
Decent motors, not sure what kind of torque they have, but I'd suspect not quite as good as the looks might indicate. One of my DIY tables is a K33H based table.
IMO, motors have come a long way since what they had to live with in the 50s/60s.
The VPI Classic was loosely patterned after old Empires and RoKs. The motor in the Classic seems to have at least as much torque (or more..judging by how quickly it gets the platter up to speed, a platter maybe 2 or 3 times as heavy as that on the Empire) but it also is much more quiet.
I know edd9000s DIY turntable uses a Berger Lahr 20 pole sync motor, 2 phase. Fairly small, and it spins up his 30+ lb platter up to speed in less than a revolution. It's really impressive.
seeing all them high end bely drives out there going for big bucks, I doubt that any realy sound inferior to us po boys under 500 dollar tables. They wouldn`t be selling them ifn they sounded bad now would they?
Granted them belts on them high dollar belts maybe look like strings more than belts on them
