I did and they told me that "it looks like the finish is in excellent condition and any swirl marks you see are within the tolerance production levels." I don't think it is. It seems that someone at the factory took a very rough rag and started wiping the speaker down before boxing it. I thought i attached a picture on my first thread...you can see the haze and fine scratches. Sounds good but feels used.
Now that I see the pic I would return them at whatever means necessary. If you just got them there must be some kind of return policy whether online or brick and mortar. Unacceptable for a product in that price range IMHO.
Any Kefs with the uni Q driver should be facing straight forward, not pointed in toward the listener.
Hey, that's really great information, Ken. I never thought of referring to the owner's manual. I'll see if Ebay can track down the original owner and see if he still has the pamphlet from 1993. Or, if he doesn't know the answer to my question about location, he'll just refrain from responding.The graphic illustrations that KEF ships with every pair of speakers (what they consider "instructions") show the recommended minimum distance to walls and apart from each other.
Yes, I think that will be my first option from now on. The way I figure is, Why bother asking a human being, when I can just "google" it?You can easily just download that from the KEF websites.
Yes i am a pickering fan and user ...... but ...after much trial and error testing , the nagaoka mp110 is a faster , cleaner less bloated sounding cart for the kef r 300s. The low end stops, and starts are very immediate, highs and cymbals are probly 10% cleaner and open with no rolloff, and what i didnt realize is how much surface noise was behind the music with my beloved pickering XV 1800s by design. The Nagaoka cart rides high above the record with a tall stylus and cantilever down to the record , this reduces any noises from the record reaching the cart.So for us KEF fans..... What kinds of Phono carts do you match with your speakers for that synergy??
I use both a Stanton 681ee and Grace F9e Super with the 2nd tier Sound Smith replacement stylus on a SE 3009 II improved with fluid damper. Didn' like Denon 301 using the AT transformer.
Boy i dont know if it would best those newer design carts you have, but compared to my very old carts the new design of the Nag is a improvement.I'm now curious to try one of those Nagaoka MP110's. Thanks! I wonder how it will compare to the Ortofon 2M Red I'm using now or the Sumiko Pearl I had until my wife took it out with her duster.
I recently bought a pair of 105.4s, which sound very nice. However, one of the terminals is very loose, as if a nut inside the cabinet is unscrewed. Occasionally the speaker will cut out if the speaker wire isn’t aligned just so. It’s eventually going to drive me crazy.
But: How do I safely remove a bass driver in order to get inside the box? I unscrewed the screws on the lower driver but it wouldn’t budge, and I couldn’t figure out a way to pull it out that wouldn’t cause some damage (like pliers). It’s really wedged in there. Anyone have experience popping these out?
A very timely question...
I just picked up a pair of 2nd hand LS50s over the weekend. I tried them first with a Signet TK10 ML. They sounded very detailed with great separation and superb imaging, but a little thin in the bass and lower midrange. I'm now trying them with a Pickering XV-15/625E. Perhaps a little less detail, but a fuller sound, still with great separation, but not quite the imaging of the Signet. I need to hook up both tables at the same time so I can do a proper A/B comparison. The Signet TK10ML has a very low output for a MM cartridge (2.2mV) and I think that may be influencing what I'm hearing. I have to really crank up the volume knob to get the LS50s going. The Pickering, with a more conventional 4.4mV output "seems to be" a better match, but I want to run a true A/B test with matched volume levels to get a more accurate comparison. I REALLY like the imaging with the Signet, but also like the fuller low end with the Pickering.
I also plan to try a couple of my vintage Shure cartridges, and will probably also try the AT132EP as well.
Still need to work out the placement (will need to move the larger JBLs out of the way for that), but here's how I'm running them currently (driven with a Yamaha A-1000):
