These were the two reasons I did the timing chains, one of the tensioners had lost it's gasket and one of the plastic guides had broken. the chains would slap like hell on startup, but were still quiet once it was running. I'll say the only slight difficulty was getting the passenger's side valve cover off, the book wants you to remove a motormount and shift the engine slightly for clearance between the cover and the A/C box on the firewall, but it can be carefully slipped out of there with a bit of patience.
View attachment 2360715 View attachment 2360716
Hi Sam, no, it's not 2007, it's 2003. Maybe the Towncar got the newer setup earlier than the other Panther chassis cars? It's a Cartier, with the factory dual exhaust, HID headlights, rain sensing wipers, and other things the less expensive Towncars didn't have (Better, thicker & softer leather seats and factory navigation are two more) . And yes I have experienced Doorman's quality issues firsthand so the timing set I installed was from Cloyes. It's been two years since I installed the manifold & water pump and a year since I installed the chains and thankfully all is well at this point![]()
Some more Towncar maintenance pics...
Here are some pics from when I replaced the front bearing hubs. The left front had gone bad enough to develop some play so I did both sides at the same time. The ABS sensor housing had gotten SO rotted that water got in, and when I took it apart and saw how bad it was I was amazed the ABS light never came on. All of the hardware unbolted fairly easily, but the steel (Iron?) hub had dissimilar metal corroded into the aluminum bracket so it took some fancy slide hammer action to get it to pop free (the other side came out easily). Of course I had to take one of the bad ones apart, just to see the inner working of it
And yes, since they are still available, I bought Motorcraft replacement hubs.
View attachment 2361367 View attachment 2361368 View attachment 2361371 View attachment 2361372
After market parts are cheap and readily available. Even a lot of original Mercedes parts are quite reasonably priced.
I have heard that original parts are getting more and more expensive for the older cars like mine, though.
On my red C200 I replaced the brakes (pads and rotors) front and rear, a year before I traded it in for my silver one. I got OEM quality parts (from ATE) for about €150. You can get no name brakes for about €75
A cheap radiator costs €70, and a high qhality one, maybe double that.
All in all, it´s quite affordable
In the 7 years that I had the red C200 I think I replaced the following:
Battery
Water pump
rear tires
brakes
lower ball joints
I think that all cost around €400
This is MY car, just like the Crown Vic seems to be yours
edit: I replaced the thermostat and did an oil change today. Changing the thermostat was a 15 minute job. There is a spigot (?) on the bottom of the radiator to drain the coolant, and the thermostat is right at the front of the engine. Very nicely designed
