richardpp
Well-Known Member
If the trace is okay, can you confirm the following:
the voltage at R18 the same no matter which jumper is connected,
the voltage at R18 is still 0V.
With only one jumper in and applying 20 VDC, the relays click in instantaneously. Voltage at R18 stabilizes at 12V. Falls to 0.8V at about 7 seconds after power off.
With both jumpers connected, voltage at R18 goes to 0 V at power on, and stays at 0 V at power off. Very different from what you are seeing.
