Show us your flea-watts amps!
I am not suer, They were pulled from turntables, i am not sure of the actual model numbers on them.
Ah. That was the hint I needed. Might be an Encore PT1025.
There were a few different models. The PT 1010 / 1020 and the PT 1015 / 1025. Probably just minor differences between them all but I've never looked closely.
Here are the Sams in pdf, which can be enlarged to view details:
Super helpful as I have one that is in need of repair and have wanted to find a schematic for them. Thank you!!
My most recent flea power build is this breadboard style SE UL EL34:
It uses a SMPS and has no soldered connections. Details here:
Oh, @FlaCharlie : you are well advised to put in a cage... Who knows ? It may escape ! :biggrin: ;)
Very "Electrical Cabinet" wiring, that said... :cool::cool::cool:
T
"What input tube is that?"
At the time it was a WE 310B but I'm now using a WE 310A. No difference as far as I can tell.
Luxman Sq-N150, 10 watts per channel, single tap, 6ohms
So, I found the ideal opportunity to trade my Luxman SQ-N150 for the LX-380 though I had to drive to Cornwall NY to do it. It's American voltage, has a warrantee and I picked up at Hudson Valley Hi Fi in the above mentioned quaint little town along the Hudson River. The LX-380 is rated at 14 - 20 watts per channel at 1000Khz depending on the speaker load but realistically for full bandwidth 20Hz - 20Khz at 1% distortion its probably about 6 watts per channel. Still more than enough to make my Klipsch Heresy IVs go very loud if I wanted them to! An extremely nice sounding and elegantly crafted component. :music:
SET amps I built for my mono hifi rig. :)
SE2A3 - James nickel plate choke loaded 2C22 + Hashimoto H203S OPT
SE46 - triode connected 6C6 > triode connected 46 dual-grid tube + classic UTC S14 OPT (~ 1250mW)
Asano-inspired SE210 amp (~ 1500mW)
I don't think I ever posted a picture of my parallel feed 6V6 amp. I mentioned it earlier in this thread and included a link to another forum. It's just over 3W and uses a 6V6 as the driver with plate to plate feedback. Really nice and open sound and the FR is -3dB at 15Hz and 65kHz at 1W. Now working on a not-so-flea-watt SE amp at about 15W. Similar concept but GU50 and 6p15p tubes.
Progressed from this
to this
to this
this is really cool. id luv to see a schematic for this amp--have you posted it in a build thread?
Pics and such
