DocMontana
It was the first time I had done it and I was a bit nervous at first, but the kit I bought had everything I needed and very good instructions, so the operation was a total success!
I picked up a pair of M-80 CV's today. I heard them on the guy's tube gear and they sounded great. I will take some pics and post them in awhile. I think my Onkyo M-504 will make them sing nicely.![]()
How do you think these would do with electronic music?
I have had speakers that sound good with basically all other types of music but the speakers I’ve tried have all been either too muddy or too tame and don’t move enough air to handle it.
I need speakers in the $500 range that sounds very good on everything. Don’t have to excel on any one type of music but I want them to sound very good on everything. Don’t have the budget or even the space for multiple setups.
Listen to many types of music from vocalists like Sinatra and Patsy Cline to newer electronic music like San Holo and dream pop like Lana Del Rey. From Johnny Cash to some classic rap like Beastie Boys and Rakim. From CCR to Norah Jones. You get the picture.
Maybe it is an impossible ask for the $500 range IDK.
UT12R Does the122W2? fit into the frame Casing of the. 122T2 frame. Find a casing and cone. For the 122 W2. Thank you.I have a pair of HED (High Energy Design) Cerwin Vega UT12R towers that are extremely rare. The woofers did not sport the "red" surrounds, and the cones are a thick non-pressed paper BLUE color in the aluminum frame. The woofers are the 122T2 model. I have yet to find a 122T2 woofer to replace a missing one (was gone when I got these) though I missed out on a pair several years ago needing rebuilt. So instead I rebuilt a pair of 122W2 using a pair of blue CV cones I found, but they aren't quite as thick as the original T2 cones. However they do sound just as good as the 122T2. The UT12R has a Rear firing midrange, rear 6" Bass port, Front firing Mid, tweeter, and woofer. The crossover has pots for mid and highs. These are a "reflective" speaker and need spaced out from the wall (or corner) about 18 inches or so for best reflective "ambience". Bose wasn't the "first" to use reflective types of speakers.
An old Magnavox console I just scrapped out (kept the good stuff) utilized sealed (styrofoam) speaker enclosures with front firing woofer, and side firing horn in each channel. It was probably among the "top best sounding" of the era.
Yes, the aluminum frames are the same as the 122W2 as well as the same magnet strength with 2" voice coil.UT12R Does the122W2? fit into the frame Casing of the. 122T2 frame. Find a casing and cone. For the 122 W2. Thank you.View attachment 3144041View attachment 3144043
15T's were very nice...The older models with powerful 12 and 15 inch floor facing woofers mentioned above were the 12t and 12tr and the 15t. They have 6" and 8" midrange drivers, respectively, and flared horn tweeters. They also have rear facing horn tweeters which gave them some added ambience. I've worked on the 12 tr and own some 15t's and they have a smoother sound and very deep bass. I've easily rattled windows with 20 hz test tones at even low power. Many years ago Cerwin Vega also produced a giant called something like metron suft-fet with planar tweeter arrays and a 15 inch subwoofer. Never got to hear them.
