marvelus10
That discrepancy caught my eye as well. I also did a google search and there is more pictures of X's with saggy badges.
It looks like there's ample room for the bearing shaft to fit between the coils. Whatever differences are needed to accommodate the larger bearing shaft would be minor.I still think it's different since the "bearing" that pops out on top of the flange is obvious larger on the x because of a thicker diameter of the axle. I took a close up of the internals of my motor when I had it open for re-gluing of the plastic ring that got loose and made the scraping sound.
There is not alot extra space around the coils for any bigger bearing so I believe the internals of the x model motor is littlebit different.
I'll ask again: What did others make of that GT 2000 entry in that Japanese blog I linked above?
The photos on the hardoff site scream HiFiDo to me.
It's easy to open by just take a hard grip with your fingers around the round "upside down bowl" with the axle tip coming thru. Then just lift it up with some hard force while your other hand holds the base/bearing part. Now turn it slowly while dragging those parts apart. The fit between the axle and the bearing will create a vacuum and the magnet inside will also struggle some to give you some more force you need to overcome. After some struggling bit by bit it finally will be separated. The top/magnet part of the motor just looks like this:Henrik, how did you open the motor?
My best guess why Yamaha did like this is spelled: profit. Why include the brake if that could only be achieved with an additional item to sell as the YOP-1This part stuck out for me,
Especially thanks to the YOP-1, the brake function works, which is really nice for me who had a hard time designing the brake circuit.
However, it is still a mystery for me why Yamaha made the brake function work only when using an external power supply because of the design of the player as a whole.
Because all the brake functions have already been included in the drive circuit.
I would be interested to see if it is possible without the YOP.
.Thanks Henrik, it was surprisingly easy to separate.It's easy to open by just take a hard grip with your fingers around the round "upside down bowl" with the axle tip coming thru. Then just lift it up with some hard force while your other hand holds the base/bearing part. Now turn it slowly while dragging those parts apart. The fit between the axle and the bearing will create a vacuum and the magnet inside will also struggle some to give you some more force you need to overcome. After some struggling bit by bit it finally will be separated. The top/magnet part of the motor just looks like this:
Normally the motor is secured for breaking apart into these two pieces by the black Yamaha cage that the motor is attached to.
Yes both acting as a dust guard but mostly as a ringing damper so to speak. If you use a small knife it might be better to take the plastic ring out completely before re gluing. Makes it more easy to get the glue where you want it to be. Just be careful since that plastic ring is quite fragile and breaks easily. Without that plastic it's a good bell from that metallic "bowl' when picking with your nail to it. With the plastic attached correctly it sounds almost nothing when picking and without any ringing at all. Huge difference!Thanks Henrik, it was surprisingly easy to separate.
I can see that the plastic ring you said caused the scraping has partly come loose and needs to be re-glued. Its purpose appears to be as a dust guard.
This motor is so simple and elegant!
OK I reply to my own earlier reply regarding the brake. As I see it now when I have checked the power board some more (where all cables connects) there would be three different ways to do the brake modifications:My best guess why Yamaha did like this is spelled: profit. Why include the brake if that could only be achieved with an additional item to sell as the YOP-1.
Anyway the start/stop button have two channels: one is for cutting the 24V power from the power board to the control board. The other channel is for the start/stop signalling to the control board. When using the external YOP-1 the power overrides this cut out of the power switch and the brake is enabled when platter is spinning and the start/stop signal is cut by the switch but there still exist power coming in to the control board.
So yes by putting a jumper over the switch for the power channel makes the brake be enabled but you get the annoying blinking of the speed indicator led all the time when the platter is stopped and the GT-2000 is left in "stand by mode". Sure you can cut the power coming in from the mains by external switch.
Great information @808_state. I removed the plastic ring (it's actually magnetic) cleaned it and the surface of the motor housing that it was glued to, applied a thin layer of E6000 adhesive, placed some thin strips of plastic at 5 points on the perimeter of the motor and put the motor back together. I'll give it 72 hours to cure before I test it.It happened early on into owning mine and I was pretty freaked out when I heard that scraping sound. It is one of the older units and the original glue never dries out but simply loses its ability to adhere. Never tried prying it apart but simply injected some rubber cement between the bell and ring, jammed some credit cards in between/below for support and let it dry overnight. It's been trouble free ever since. It would be interesting to know if they updated the glue in later runs.
Congratulations, Pass Labs phono preamps are highly regarded.Gentlemen, earlier I posted I was gonna buy X brand of phono pre, well I didn't. I've just sent in payment for a Pass labs Xono to an AK member instead. Now the wait is on.
Thank you very much for the explanation. I could see the reflection of other components in the sides of the GT and it reminded me of HiFiDo.
A very unusual color for the clear laqueur of our belowed GT-2000:
http://yahoo.aleado.com/lot?auctionID=514385955
