Thanks very much for the info, @vintagerocks ! Much appreciated. I did wind up going after those EPI woofers... looking forward to getting them later this week.
Finally, generic questions, because I am such a newbie to this:
1) The resistor... if I'm understanding the Human Speakers schematic correctly, this is a 2ohm / 5W resistor... do i have that right? Given that, does it matter at all WHAT KIND of resistor? Metal oxide film, or cement ceramic? (PE doesn't seem to carry 2ohm/5 W resistors anymore... probably not very popular).
2) what are the terminal connector tab things called, that you put at the end of a wire and connect to the tabs on the woofer? I haven't stumbled on their proper name and can't find them on Parts Express because of that..
3) DO i need any special kind of hot glue/adhesive, or do generic hot glue sticks from the craft store work fine? I won't damage any components with their initial heat? should I used zip ties in some kind of board instead? any concerns I should be aware of with that?
4) Does the inductor have negative positive leads, or does it not matter which ends I connect to which other wires?
5) Is it worthwhile to use better internal wiring, like 16awg, to connect everything up?
6) in my photo above, there is a little black bar thing, with solder points at each end... its connecting the inductor to the other wires... what is this thing called? is it useful to connect everything like this, or should i just solder all my leads together directly and avoid that sort of bar connector?
7) CAn I glue that fancy inductor I'm buying down, or should I zip tie it, since its "impregnated" with special wax?
8) Should I do anything to keep the fibgerglass batting from directly resting on the crossover?
@RTally , it sounds like you're suggesting I may be overthinking this... you are probably rightAny advice on getting that glue off the backside of the terminal? just chip away at it, or some other method you use so I can remove the old spring clips and rewire to the new binding posts in the same place?
Thank you again for all your guidance; I'll pare down my possibly overzealous shopping cart for the time being and use the stock inductor, etc.I was reading another person's post on how they had upgraded to a foil coil inductor and the high end cap from Jantzen and 16awg wiring, and how performing all those upgrades made these speakers the best of his pretty impressive collection. I think I just got caught up in that daydream
I'm also worried about just being unable to un-solder the old cap and terminals, and resolder the new ones in... hence my drift towards building an entirely new crossover set.
Last question for the day, I promise... where the screws for the drivers go in, the MDF is starting to chip apart. My first thought was to put some wood glue in to hold the holes together and give the screws some new material to bite into. Am i on the right track there? Thanks, a last time in this 24 hour period![]()
1+ on top, 110 on bottom.@Jhol111964 , have any photos of those models? I haven't looked up the 110s yet.
My EPI 100 woofers arrived recently, they look pretty niceAnd I stopped hemming and hawing and put in my Parts Express order for the parts I need for the Genesis 2's (and for my KLH 20's)...getting excited about making these speakers sing again
I also successfully used my shop vac to mostly fix the poked in dust caps on the Passives.
I noticed that there isn't as much travel on my second hand EPI woofers as there was on (suspected) Boston Accoustics drivers that came in my Gen. speakers... does that line up with the experiences of other Gen. owners?
I'd like to see a pic of your 66's please .Genesis made their own woofers and tweeters. The long excursion is normal for Genesis. My 66's 8" woofs have a peak to peak of 3/4". Same for the Genesis Is and 11s I've owned in the past. Once you're finished with this project, I'm sure you will be very happy with those IIs.
Practically twins, in terms of the construction! I'd like to get as set of those EPIs someday, as well as a pair of Advents or AR's.Very similar construction: https://audiokarma.org/forums/index.php?threads/epi-100-restoration.874537/#post-12840442
