cpt_paranoia
Addicted Member
Both are acceptable, in the sense of making less strong.Everything is well-damped. (Dampening is making something wet, this isn't that.)
I carefully dried my sand, though...
Hello James and other KEF owners,@Dony
I’ve been following your posts. Congratulations on your 107s. I wouldn’t be concerned with the crossovers now. The ferrofluid is more important. Have the replacement ferrofluid on hand since you have to open them to check.(and refresh them anyway) Look for the seller on Ebay who offers free shipping. His product is the same as all the others for less. If you have not done this before watch the videos on YouTube. Then watch them again. No room to make a mistake. Don’t put a soldering iron anywhere near the tweeter, cut the wires and splice them when finished.
I’m seeing your electronics with the speakers. What are you doing for power? These 107s require an amp with some serious stones.
Wimpy thirty or forty watt receivers just ain‘t gonna cut it.
Happy listening!
James
I have a question for those members that have experience with vintage KEF reference speakers and amplifiers. In my specific case I am looking to purchase a vintage Perreaux PMF 3150 amp and have it serviced and recapped to use with my Kef 107s.
From what I have read in some threads the combination of KEF and Perreaux were very desirable back when they were new, would this be a recommended path? My other option is to hunt for an Bryston 4B sst2 or 4B3 but they are quite a bit more than the Perreaux and I am not sure that the SQ will equal the extra dollars spent for a vintage system.
Any feedback is greatly appreciated!
Thanks
Don
Thanks for the feedback Ken, I am kind of leaning towards making the plunge on the Perreaux. I am hoping @Raynald and maybe @canuckaudiog will see this thread and chime in as I believe they have intimate experience with both the KEF and the Perreaux.Looking at the specs for the Perreaux PMF 3150, it seems you've got a VERY good 350w/ch class A-B power amp there with a damping factor of 400 and low distortion. Use it and enjoy it!
Hi Dobieguy,Hey Dony
I’d have serious reservations buying an amp 35+ years and then finding a qualified technician to overhaul it. Big and heavy, shipping costs could be substantial. I’d also would want to know about the availability of those MOFETS in case of an issue.
I’ve been using a Bryston 3B for years. It has never been serviced with thousands of hours on it.
Still dead quiet. The factory supports mostly everything they’ve built. I’ve used other amps both tube and solid state on my REF102s but the Bryston makes the REF 103/3s come alive.
Good luck
I recently bought a pair of KEF 101 Reference speakers (made in '81), having wanted a pair for about forty years.
Now I need to find more suitable amplification for them than the HK 740 and 570i receivers I've
been using so far. Any suggestions would be welcome-
Thanks very much for your helpful reply, and I will definitely be reading through the whole thread.Pay no attention to the 20-100w power recommendation. You could drive them with a 500w amp and be just fine, so long as you don't crank it to the point of distorting the sound. And, although they do have built in overload protection, I wouldn't push it to find out if it really works.![]()
KEF Model 101
Blog High-Fidelity Stereo. Vintage Audio and Hi-Fi Equipment, info, specifications, descriptions,stereonomono.blogspot.com
KEF's tend to sound best with high power/high current amps. And, with the 101's low efficiency (81db) you're going to need some juice behind them to get them to shine. As such, I'd recommend separates (amp/preamp). I drive my 104/2's with B&K ex4420 amp, and Schiit Saga preamp. There are many used amps out there that would easily fit the bill for these speakers. You might read through this thread to find out what others are using.
Thanks for another very useful comment, James! All well taken, and I have no expectations of thunder from the 101s;Congratulations on your new to you KEF! Long time owner here. Forty years is a long wait, you don’t want to jeopardize them with the wrong electronics. I’ve powered mine with SS (Bryston, Levinson, Counterpoint) and tubes (Scott, Fisher).
None disappointed. Quality over quantity works best with these. I’m not sure what you mean by oomph. If you’re expecting them to deliver thunder you‘ve got the wrong speakers. Damage the tweeters and you’ve got bookends. The overload circuit is a known problem area.
Read everything on AK (also Pinkfish.Net) pertaining to these and all the LS3/5a threads.
Put them on good, solid stands out in your room and be prepared to be amazed!
Happy listening
James
Hi nerdorama,I used a miniDSp on some 103/3 speakers a few years ago. You just need the EQ curve from the Kube and do a bit of work in the DSP to copy it. I slso used a graphic EQ app in my PC music server which worked very well. A 1/3 octave graphic equalizer can do the job too.
Hello fellow KEF owners,
I wanted to ask if anyone has replaced their KEF K-UBE with a MiniDsp or similar type device? My KEF 107 KUBE has recently developed some channel cut out issues in that when I first start up my system I need to engage/disengage the monitor tape/source button on the back of the KUBE repeatively in order for both channels to operate properly.
Once both channels engage as required then it seems to work fine until I restart my system. I suspect it is a faulty tape/source monitor switch and unfortunately I think the part is an unobtainium as the K-UBE is approximately 38 years old. I recently had the K-UBE recapped and had new opamps installed thinking that repair might fix the issue, I've also deoxited the monitor switch but unfortunately the problem persists.
Thus, I think my next best option would be to purchase a Minidsp 2X4 HD and use it to control the overall EQ curve for my KEF 107. Anyone have any recommendations or comments about this approach?
Thanks
Don
Does anyone know what the KUBE does for the 107?
Hi idf.bts,I have 3 sets of 107s and sold all 3 Kubes to members here about 2 years ago, they were sitting for like a decade. I never used the KUBE, I could always solve issues with room placement.
The issue you are reporting seems fixable. A component may be hard to obtain, but something like a switch is relatively interchangeable, its just may not look identical.
Hi nerdorama,I don't think a microphone is your best option but you can measure the speakers without the KUBE EQ and then program the miniDSP to flatten the dips and peaks. If you want to download REW, Room EQ Wizard, and learn to use it you can generate an EQ file that will download directly to the miniDSP.
Does anyone know what the KUBE does for the 107? It may only be a bass boost in which case you don't really need it. There are many ways to accomplish a low frequency boost. My 103/3 KUBE performed a pretty wild EQ, a lot more that just a bass boost. They were very un-flat with it. This was the EQ from the 103/3 KUBE:
