Tekniknissen
Brunomarcs I'm sure you can be calm about the performance even without that cabling. If your power supply isn't causing any hum now then it's obvious of good quality and good design without any leakage to the mains ground. Otherwise ground loops might mess up things when there are loops no one even thought about. If I remember correct that internal ground cabling is more or less coming back to the original internal powersupply's 0V thru a small capacitor. That meaning the only "hard connection" for hum and interference to pass is thru the screen of the cabling out from pickup/tonearm to the rest of the stereosystem and then make all system coming to the same signal ground. Now when the internal ground cable is missing nothing changes as long as motor is powered by a good power supply having the same ground reference as the rest of the system.
So now you all think: what? Ground is ground... Simple. Yes but power supply doesn't necessarily need to have the 0V output to be at the exact same level as mains ground or the rest of the stereosystem signal ground. If not same level then the whole motor/platter might start to act as a huge capacitor to the tonearm/pickup and introduce hum/interference to the signal from the pickup. Now there is nothing keeping the power supply's 0V to the systems ground level any more since that cable is missing between motor and tonearm. So it might work or it won't. All depending on powersupply design and selection of pickup for example.
I'm working with EMC (electro magnetic compatibility) almost daily so it's alot to consider when designing electronics and everyday something new is discovered about complex signal paths and how interference can travel in a system.
