The original Zeners are marked 2456R.
Does that indicate they are 24V? I'm not familiar with how these are marked to indicate their voltage. I used BZX55B22-TR for replacements, which are 22 V.
It does seem a lot of of the generated heat is now being dissipated by the side wall the resistors are mounted on as well as the outer side panel. After a couple hours of power on, the side panel is pretty warm along with the top over that area.
Being a scientist, I always want data, so I brought a temperature sensor home from the lab to do some temperature readings in the area of the PS. I've placed the sensor about 1/2 inch away from the two resistors hanging in the air, so I can get an idea how warm that area gets.
It's a bit hard to see, but the thermocouple wire is threaded through a vent opening in the top and in the shielding over the PS internally. I also fitted the graphics card fan on the wall separating the pre-amp from the PS, taking power from the meter light feed. Initial rough tests showed the fan does make a difference, but need to do a time vs. Temp study with the fan on and off from cold start. Will report back with results.
The last parts from my initial order are the two filter caps, so I will likely fit those in next. Meanwhile, I'll need to look at what's needed for the protection board to see if I'll need to make a new order.
FYI, I believe I have determined that the "cut" wires on F-2497 referred to in post #4 were added when the OTs were replaced to aid in measuring the bias voltage. Taking a closer look at those wires, there is enough room on each to attach a micro-grabber for measurement with a DMM.
These two junctions are connected to pins 2 & 4 on F-2512. I think a previous tech determined that something needed to be added to measure voltage on those two pins, since this unit does not have the F-2510 connectors needed to attached the DMM leads. At first, I tried measuring points 2 & 4 holding the pointed ends of DMM test leads on the solder pads on F-2512, but of course that leaves one with no hands to adjust the VR! It becomes a matter of trial and error if one wants to follow that procedure. However, using the wires on the F-2497 boards works well.
