marvelus10
And another one,
And another one,
I agree, the copper platter looks sweet.
I can't say that I hear a sound difference with the new feet.
I've got one but have never used it. It's been packed since I moved a couple of years ago. I think it would look great with the copper platter.Perhaps you should change the record clamp to copper as well ?![]()
It has a Hana ML on it and it's feeding an Allnic H1202 into a Luxman 550AXII and modified Klipsch Quartets with dual Rythmik servo subs. Still figuring out the speaker situation but it does sound great.
Hello,
did anyone experience with an outer ring? Not as a tool to flaten a record, but as something which goes unter the record to add to the inertia moment of the platter. I have not testet it but as the GT2000 platter is oversized there could be enough place on the outer "spare" space of the platter. And if one uses an additional record mat inside, everything should be of the same high again.
Best regards Wolfgang
Hi Wolfgang, several members, myself included, have heavy platters for their GT-2000's. I have stainless steel (36lbs) and copper (40lbs) platters. I've posted a number of photos in this thread (most recent is post# 2998 on page 150).Hello,
Thank You Mark,
Could you tell me how much did you pay for or how much I have to expect? Could you detect any sonic enhancements?
Congratulations, the more you listen to the GT-2000 the more you'll love it!My GT-2000 arrived. Well packed but still some very minor damage which I attributed to mishandling by UPS. Dustcover was new and it's damaged in right rear corner but since cabinet is fine, the impact must have been vertical compression from dropping and not a corner impact. Absolutely no mar to the cabinet. Operates well but i have a brand new Nag MP-200 cart on the AT headhshell so I need some time to break it in. Even new it sounds very good but i expect it to mellow and get more clear with use. Only played for 45 mins so far (Crime of the Century, MSFL). Putting on the album I am most fsmiliar with next, DSOTM, 2nd UK press in ex+.
Wolfgang, the stock platter should be sufficient, but I had a bad experience with a machinist who failed to fabricate a quality platter using my stock platter as a model.Thanks again Mark,
Artisan Fidelity is a very superb company. Sounds to me now that an heavy platter is a must.
One thing I do not understand, why you supplied them additional with the motor. Would the stock paltter not be enough?
Regards Wolfgang
