Tekniknissen
The spindle is conical with 1:10 ratio of width/height ratio. The problem is not the "cone" itself. I believe the problem is the small shelf sitting at the bottom where the cone ends. If platter bottoms out on this shelf instead before the cone bottoms then there will be a problem by a wiggling platter. So obviously this "cone drilling" have been put too deep up to the platter for Mark. I believe an insert or to modify the bottom of the platter would do the trick. If modifying the bottom the whole platter might sit too low perhaps and there might be a clearance problem instead to the plinth.
