The Little Fwend works with the YA-39 tonearm. The YAL-1 is not difficult to find.
What i read is that you allways have to lower the Fwend again for the next record. That is with the YAL-1 not necesarry when i am right?
That's correct, the lift arm of the Little Fwend must be manually reset which involves pushing the lift arm down and is a very simple procedure. If not reset the lift arm will act as a tonearm stop. By the way, I bought the Little Fwend to use with a Thomas Schick tonearm.What i read is that you allways have to lower the Fwend again for the next record. That is with the YAL-1 not necesarry when i am right?
I don’t think that arm is much of an upgrade, if any, from the stock arm. Most everyone here from what I can tell keeps there ya-39 which suggests to me it’s very nice. There is a thread on tonearm upgrade for the GT but doesn’t really go anywhere, as in not a lot of folks worry with it for one reason or another. Don’t want to chop up your plinth and ruin its value but I’m gonna cut in to mine.I was watching on YouTube a video on the GT-2000 see link
it seems the owner of this turntable has used an aftermarket tonearm & mounting plate. Anyone have any thoughts on suitable aftermarket tonearms and mounting plates/ brackets for the GT-2000? I ask because I am concerned if (God forbid) something happened to my tonearm I would not have a backup.
The Thomas Schick tonearm hasn't been mounted yet. I know it will fit on the GT-2000 plinth, though the dustcover may need to be removed while in use. I've measured and the dustcover will be able to close when the 'arm is in the resting position.Yeah the SAEC-407/GT is almost impossible to find it’s been on my Hifido request list for the last 5 years. The odd occasion I see one on hifido - it’s always consigned. That was why I’m asking, if there are other aftermarket tonearms. I think there may be some other tonearms possibly Kuzma that may be set up similar to the YA-39. I’m hoping someone might have an idea here. Mark B mentioned he had a Thomas Schick tonearm, Mark I’m very keen to know what your thoughts are on mounting the TS on your GT-2000.
So I received my second GT today and wouldn’t you know it’s busted up. It just goes in one ear and out the other with them, either way my CC company is gonna dispute the charges, maybe I’ll get the table for free unless they come pick it up.
Everything works and looks good you know. The arm column has a thin membrane type substance, what is that?It’s really a shame, the table appears unused and was in great shape. They left the dust cover installed and the platter placed on top of it, yep! The cover snapped at the hinges, moved forward and pulled the speed sensor out by the screws. Bent the finger grip on the hs and knocked the cap off the 45/33 It can be repaired and there isn’t any permanent damaged or scaring to anything but should’ve been avoided. View attachment 1652595 View attachment 1652603 View attachment 1652606 Everything works and looks good you know. The arm column has a thin membrane type substance, what is that?
