Well on my broken GT it seems buyee Tenso is dragging their heals and says it’ll take two to three weeks to resolve the issue after having seen all the photos of the damaged unit, no surprise there! meanwhile my CC company has issued a full refund of both shipping and the price of the unit! I’ve taken it part already...........
I will also add that if you have too much anti-skate weight a funny thing will happen. The end of side lift will trigger lifting the arm, then the weight will pull the arm back away from the spindle and away from the trigger zone, which causes it to drop and then the stylus plays the last few seconds of the record again (and doesn't trigger the lift the second time). Even though this is the "correct' amount of weight for my test records to sound their best, it's not optimum for the lifter so I have to use less anti-skate.
jblnut
You don’t need to solder the Yal-1 there is an electronic connection between YAL-1 & GT underneath the tonearm assembly it’s easy to follow the pictures in the Japanese manual just take your time
Thanks Mate.
I don’t have the lifter and manual yet, it is coming from Japan. Thanks for the tip to look at the pictures in the manual.
But I’m curious to know, does the installation take place from under the turntable?
No you have to lift the tonearm out of the the tonearm well (hole) there are a couple of screws securing the tonearm mechanism to the turntable enclosure (the black particleboard). You unscrew these and carefully lift the tonearm mechanism out - see this link as it’s a PDF of how to install the YAL-1
https://jp.yamaha.com/files/download/other_assets/9/316269/YAL-1.pdf
Thanks, I’ll study the pictures. Installing the controller on the side of the arm is not clear from the pictures at first glance. How is it attached and does it require running a wire to the arm base? This is a bit confusing at this point.
Everybody, please welcome about2 into the fold. 2, feel free to ask if you have any questions. I may not have all of the answers but we are gathering a group of really happy GT 2000 owners. That is actually what unites this group. I'm not a brand fan. I just like things that work well and the GT 2000 series appears to work very well.
As far as I am concerned: That is all that I need this turntable to do.
They look incredible. Here's hoping that the platter center conical 'female' receptacle, which mates with the motor-spindle male conical profile, is absolutely accurate. I will attentively await a report on this aspect. If I am not incorrect, this has been found to be an after-market platter's 'Achilles Heel'.
Wow....that is beautiful.
The stock aluminum platter is ~13lbs.Stunning. What are the weights compared to the stock platter?
